ladygaga Junior Member
  Posts: 64 Status: Offline Joined:
| | How do wood stoves work for tents? (28th Nov 21 at 12:59pm UTC) | | How do wood stoves work for tents? | |
candymika New Member
 Posts: 21 Status: Offline Joined:
| | Re: How do wood stoves work for tents? (29th Nov 21 at 2:37am UTC) | | | Most of the firewood is burned in a well-ventilated place, because it smokes a lot when burning, burning in the tent, I don't have a good solution.earn to die | |
freestown7 Junior Member
  Posts: 69 Status: Offline Joined:
| | Re: How do wood stoves work for tents? (29th Nov 21 at 6:11am UTC) | | Oxygen is a very important player when it comes to fire, but too much of it can cause the fire to burn through the fuel very quickly and you risk over firing the stove.
oliviabacker Junior Member
  Posts: 56 Status: Offline Joined:
| | Re: How do wood stoves work for tents? (29th Nov 21 at 6:13am UTC) | | | Hi, I recommend to check this amazing mini tent wood stove https://hot-tent.com/products/small-wood-stoves-heat-resistant-glass. The main feature of the "Caminus S" stove is that the side walls are made from heat-resistant ceramic glass. This glass offers superior heat emission compared to conventional steel and also serves as an additional light source inside the tent. Best of luck | |
Lucas John New Member
 Posts: 1 Status: Offline Joined:
| | Re: How do wood stoves work for tents? (30th Nov 21 at 10:52am UTC) | | | You can search the same query in the Google search bar. Whenever I get stuck with anything, I search it in Google, always getting an answer. For example, once I searched for essay writing service in Chicago, I got the best person providing academic services in the state. So I would recommend you if you use Google to find an answer to this. Thanks. | |
